Powerlogic Easergy P3 Protection Relay
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Powerlogic Easergy P3 Protection Relay
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
MGZ010
MGZ010
Cadet
Posted: ‎2024-04-20 04:29 PM
Hello!
could someone example why the real power kW in the status display is showing negative even thought the apparent power kVA is positive.
A little background: we have a set of totalizing panels for our generators. Each generator is connected to a incomer feeder and after bus section we have two outgoing feeders…the relays on these outgoing feeders read negative kW while the total kW in the Bus Section is positive.
Thank you as you explain.
Replies 0
