Easergy P3 - Access Device Configuration Via Serial Adapter (VSE 002 - RS485)
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Easergy P3 - Access Device Configuration Via Serial Adapter (VSE 002 - RS485)
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P2
Back to Protection & Control
Mohammad_Dm
Mohammad_Dm
Cadet
Posted: ‎2024-03-21 12:18 AM
1306
Greetings,
I have a P3F30 relay and I can access its configuration via front panel USB Type-B connector using Easergy Pro. My relay is ordered with a VSE002 RS485 connector and it does not have any Ethernet RJ45 connector. I can read values using MODBUS from SCADA but I cannot access its configuration remotely via Easergy Pro.
Is it possible to access the relay configuration via the serial connector at the back (VSE002) ??
Regards.
  • Thumbnail of PowerLogic P2
    PowerLogic
    PowerLogic P2
View products (1)
  • Application cases
Mohammad_Dm
Mohammad_Dm
Cadet
Posted: ‎2024-03-30 02:41 AM
Any updates on this ??
Thiago_Carreiras
Ensign Thiago_Carreiras Ensign
Ensign
Posted: ‎2024-07-02 09:15 AM
Hello Sir,
As far as I understood, VSE002 is an interface used to connect VIO 12 I/O module (twisted pair interface to VIO) to P3F30 (Standard). You will not be able to connect on a P3x relay using Easergy_Pro through this module.
See table enclosed
BR
Thiago Carreiras
