PowerLogic T300 - Reading Modbus values from a PM5110
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - Reading Modbus values from a PM5110
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic T300
PowerLogic PM5000 series
Back to Protection & Control
matt86
matt86
Cadet
Posted: ‎2025-02-20 12:30 AM . Last Modified: ‎2025-02-20 06:55 AM
696
I have a PM5110 from which i can read values through Modbus poll at registers 3110 ( frequency ). I connected the RS485 connectors from PM5110 to HU250 though a RJ45 to 8 pin connector block.
https://www.delock.de/produkt/66471/merkmale.html?f=s
I configured the HU250 to read register at 3109 ( as there is a 1 shift) . Added Frequency in DBcore .
I am able to read freq at 3109 also in Modbus poll tool.
 When i open the HU250 web interface and try to see values on the newly defined Frequency , i see only 0.
Can someone help me how to read the Freq value from PM5110 on HU250.??
Matt
  • Thumbnail of PowerLogic T300
    PowerLogic T300
  • Thumbnail of PowerLogic PM5000 series
View products (2)
  • PowerLogic T300
Tags (4)
  • pm5110
  • PowerLogic T300
  • t300
sathishkumar_ramakrishnan
Ensign sathishkumar_ramakrishnan Ensign
Ensign
Posted: ‎2025-02-21 01:14 AM . Last Modified: ‎2025-02-21 01:17 AM
Hello Matt,
Kindly clarify, whether only frequency parameter alone not getting the values in HU250? Did you able to read other modbus registers of PM5110 in HU250 successfully?
If you are not able to read other parameters, then check modbus communication  parameters.If only particular register not getting the value, then check the data type and the addressing is mapped properly in coredb
Also please do share the traces of modbus communication, that you can get it from diagnostics.
Sathish
JYPOC
Commander JYPOC Commander
Commander
Posted: ‎2025-02-20 06:58 AM . Last Modified: ‎2025-02-20 06:58 AM
Hello Matt86,
1. how did you physically connect the PM5110 to HU250 (pin-out please)?
2. please share your RTU configuration file
BR - Jean-Yves
Ensign
Hello Matt,
Sathish
