PowerLogic P7 Relay - ETAP Library Preparation
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic P7 Relay - ETAP Library Preparation
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
38
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
Karthick-507211
Karthick-507211 Leader
Leader
Posted: ‎2025-06-11 08:09 AM
2
1264
Hi Team,
We have submitted a ticket to prepare the ETAP Library for the Power Logic P7 Relay.
The ETAP Technical team has raised some technical queries regarding this request, which are attached to this email.
Please provide your response as soon as possible.
Karthick C
@Sabhanayagan_Matheswaran
PowerLogic P7 Relay Queries.docx
  • PowerLogic P7
Tags (2)
  • sabha
Gregory_M
Gregory_M Mentor
Mentor
Posted: ‎2025-06-11 03:08 PM
1
1254
Hi Karthick,
1. Regarding IDMT curves, considering Is the set threshold:
-The minimum trip level is 1.025 Is
- The level at which the tripping time becomes independent is 40 Is.
This is valid as long as measured currents are within the dynamic range of the CT inputs.
2. Regarding thermal overload and negative sequence overcurrent threshold, the Full load amps (FLA) parameter can be defined between 0.1 and 3.25 pu.
Gregory_M
Gregory_M Mentor
Mentor
1
1255
Hi Karthick,
Karthick-507211
Leader
Posted: ‎2025-06-11 07:55 PM
Thanks Gregory.
I will share these answers with ETAP Technical team through Help Centre to prepare the Power Logic P7 Relay.
