Continue
  • My Subscriptions
  • Events
P5F30 change default configuration of the digital output
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • P5F30 change default configuration of the digital output
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
41
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
MauricioCerdeira
MauricioCerdeira
Contributor
Posted: ‎2025-03-17 12:12 PM
1202
Hello, support team.
I am configuring the P5F30 relay, in which I want to use the digital outputs for functions other than the default configuration.
I tried to turn off DO2 in Slot B, but without success, this digital output remains on.
How can I solve this problem?
Thank you very much.
  • PowerLogic P5
MauricioCerdeira
MauricioCerdeira
Contributor
Posted: ‎2025-03-18 05:33 AM
I managed to solve the problem. The default configuration uses the DO2 digital output of slot B as "latched" on any trip.
The problem is that, when the relay is turned on, this DO2 is activated and remains latched even if all connections are undone in the matrix.
To solve the problem, all I had to do was press the Reset "R" button on the front of the P5 and then select the "Release" option. The DO2 turned off and can be used for any function.
MauricioCerdeira
MauricioCerdeira
Contributor
