I used EPASS-E and CET850 to obtain a CID file for a P5F30 relay. All the CID files are a bit greater than 3MB and I am getting the above mentioned error. Is there anything that can be done to reduce the file size?
it looks a bit heavy comparing to the original size of the icd. We need some more data to check it. Please create the BFO case and attach example configuration files.
rgd
Tomasz
Hello bebemaldito,
The design is like that as the P5 file system space is limited for CID file storage. The max. acceptable CID file size is 3M for P5. Please configure a smaller CID file and try again, e.g, reduce the number of dataset or the number of DO/DA in a dataset.
The user manual will be updated to add this CID file size limitation next step. And the requirement to enlarge the CID file size limitation is under discussion.
