P3 LED EtherNet IP setup
Protection & Control
Send InviteCancel
2024-08-0111:15 PM
We have an issue where we require the LED status on the P3 advanced units (P3F30, P3T32, P3L30, P3M30) to be mapped to the EtherNet IP protocol.
I have consulted the Ethernet IP configuration instructions and the DeviceNet and EtherNet IP data model in Easergy P3 devices documents and there is no indication of how to map the LED status to the EtherNet IP protocol.
