Only one modbus TCP slave connection is working on saitel Hue, when other modbus slave is in network, modbus slave connection is breaking
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Only one modbus TCP slave connection is working on saitel Hue, when other modbus slave is in network, modbus slave connection...
Araceli_Monje
Lt. Commander Araceli_Monje Lt. Commander
28
Arun-kumar_PS
Commander Arun-kumar_PS Commander
16
HenriGRASSET
Captain HenriGRASSET Captain
15
Back to Protection & Control
Rajeev_211
Crewman Rajeev_211 Crewman
Crewman
Posted: ‎2025-08-10 09:09 PM
I have made one modbus TCP slave PHG66301A in saitel HUe, when I am checking the modbus slave data on modbus poll master, its working and reading the data properly without time out. But the moment i am connecting another laptop and modbus poll master for reading data, the connection in both are getting disconnected, means its only allowing only one modbus master.
can someone tell me why saitel HUe is allowing only 1 modbus master connection at a time not two or more??
I have two modbus master gateways which are reading and writing data of saitel HUe.
I have two saitel HUe which are having redundancy between them and a common virtual IP as well.
Both gateways are trying to read from the common virtual IP at the same time which is not working but when i disconnect one gateway its connecting properly.
Can someone check and advise me on the maximum modbus master connections from saitel HUe?
  • PowerLogic T500
  • Saitel range
Replies 0
