Continue
  • My Subscriptions
  • Events
MiCOM P138
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • MiCOM P138
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
41
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
ChhimiW
ChhimiW
Explorer
Posted: ‎2025-05-14 01:06 AM
876
MiCOM P138
any chance if someone has came across the similar issue titled "SFMON checksum error param" leading to flashing of relay LED. Didn't know what is causing it. My speculation was the configuration file is imperfect or the corrupted.
Any solution and guide would be grateful. I had to fix this. P138-671 model relay.
Regards
  • Application cases
  • IEC61850
Araceli_Monje
Mentor
Posted: ‎2025-11-05 04:04 AM
Hi, as no reply has been received for this request for more than 5 months, I consider a solution was found for this topic @ChhimiW , so I am marking this case as solved. Do not hesitate to contact us again if your topic has not been solved, thx.
Araceli_Monje
Mentor
Posted: ‎2025-07-29 08:29 AM
@Arun-kumar_PS , could you please support with this question or connect @ChhimiW with the right person that is able to help with this subject?, thx.
Arun-kumar_PS
Mentor
Posted: ‎2025-07-30 02:44 AM
@sesa164970_brid  Hello Boguslaw, Please look into this P30 query.
Araceli_Monje
Mentor
