How to controlCB over IEC61850 with P3
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • How to controlCB over IEC61850 with P3
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P2
Back to Protection & Control
Ray_Chang_EPEC
Lieutenant | EcoXpert Master Ray_Chang_EPEC Lieutenant | EcoXpert Master
Posted: ‎2023-09-23 12:55 AM
1519
Hi all:
I've been try to using control block to control Virtual input in IEC61850.
But when i send command there is no repond or action.
I can use modbus to control throw VI but can not do it with IEC61850.
Is there a example to control throw IEC61850 with P3?
Or any other way to do it?
  • Thumbnail of PowerLogic P2
    PowerLogic
    PowerLogic P2
View products (1)
  • IEC61850
  • PowerLogic P3
AndreMelo
Commander AndreMelo Commander
Commander
Posted: ‎2023-09-27 11:36 PM
1
1482
Hi @Ray_Chang_EPEC ,
to control the CBs via MMS IEC61850, you don't need to configure Virtual Inputs. The Logical Node class CSWI instaces 1-6 are referent to the Object 1 - 6 that are the controllable objects. In other words:
LN Obj1CSWI1.CO.Pos is the address you will configure at the Client (SCADA or Controller)  to open and close the CB1. Remember that the IED needs to be in Remote.
Best Regards
AndreMelo
Commander
1
1483
Best Regards
Ray_Chang_EPEC
Posted: ‎2023-10-03 08:18 PM
Hi @AndreMelo
Thanks for the answer.  I'll try on this node to control CB.
