Having an issue with P3/P5 Driver Not installing on Windows 11 Pro on Laptop
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Having an issue with P3/P5 Driver Not installing on Windows 11 Pro on Laptop
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
sesa26656_bridg
sesa26656_bridg Cadet
Cadet
Posted: ‎2023-11-17 01:13 PM
1
2013
Hello, I have a customer with an issue of not installing the P3/P5 Drivers when installing Easergy Pro 4.5 on a Windows 11 Pro PC.  When we connect the Device to the Laptop we see the USB connection show up in the Device Manager but no Driver or Comm port is assigned.  We looked at the Windows programs installed and we see that the P3 and P5 USB Drivers are not installed.  Is there a way to manually install these?  Is there an issue that you are aware of with Windows 11?  What can we try.  We did try uninstalling the DriverManager x64 and ModbusManager X64 and that did not seem to help.  Any suggestions would be appreciated.
  • PowerLogic P3
Chunmei_Yang
Lieutenant JG Chunmei_Yang Lieutenant JG
Lieutenant JG
Posted: ‎2024-01-03 09:18 PM
Easergy Pro 4.5 have been passed validation test on win 11.
propose to try the process solving the issue:
1,Reinstall Easergy pro 4.5.
2, Install the driver manually (pls find the installer files in attachment) in case of reinstall failure.
BR.
Chunmei
Downloads.7z
Chunmei_Yang
Lieutenant JG
BR.
Chunmei
Downloads.7z
