Full register list P3U30
Protection & Control
Showing results forΒ
Did you mean:Β
  • EcoStruxure Power & Grid
  • Protection & Control
  • Full register list P3U30
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
SESA528
Commander SESA528 Commander
Commander
Posted: β€Ž2021-06-03 10:26 AM . Last Modified: β€Ž2023-05-30 10:01 PM
4392
Hi teams,
I want table full register list of P3U30 (register status ON/OFF circuit breaker,...)
Thanks very much
  • PowerLogic P3
ChristopheCasa
Lt. Commander ChristopheCasa Lt. Commander
Lt. Commander
Posted: β€Ž2021-06-04 12:26 AM
4
4384
Hello
You can use EasergyPro to get the list of Modbus Register.
You can connect online to a product or create an offline configuration. In offline mode, select the Modbus protocol in the communication parameters and new lines will appear in the menu, it's the list of pages of modbus registers.
Best Regards
Risto_lehto
Commander Risto_lehto Commander
Commander
Posted: β€Ž2021-06-04 02:32 AM
2
4371
Agree, its the best way as Christophe mention. Same goes for any other protocol as well.
Something available in m.vamp.fi, but the materials there are not updated frequently
Documentation Β» Welcome to Schneider Electric Vamp Ltd!
Replies 7
SESA528
Commander
Posted: β€Ž2021-06-03 11:44 PM
4389
HI Teams,
Pls help me. Thanks very much.
ChristopheCasa
Lt. Commander
4
4385
Hello
Best Regards
Risto_lehto
Commander
2
4372
SESA528
Commander
Posted: β€Ž2021-06-04 10:54 PM
Hi @ChristopheCasa ,
Thanks for your information πŸ™‚
SESA528
Commander
Posted: β€Ž2021-06-04 10:55 PM
Hi @Risto_lehto ,
Thanks for your support. πŸ™‚
Mateus_A2
Mateus_A2
Cadet
Posted: β€Ž2025-01-08 05:19 AM
Hi Lehto.
May you please share this file again?
Link isn't working anymore.
Ty
Mentor
Ensign Mentor
Ensign
Posted: β€Ž2025-04-22 04:54 AM
Hi Mateus,
Once I needed to controll the CB from the SCADA using the P3U30, I did it as below:
Created a logic (control/logic) as per attached photo.
This logic let you controll the DO of the device (to switch it on and off.
then I used the virtual input. The virtual input has the address:
Virtual Input 1 - 403427
Virtual Input 2 - 403428
So I createt 2 tags in the scada (16 bit unsigned) for open and close the CB.
When sending the command, you should make this tag ON for 2 sec and OFF again.Address.pngLogic-CMD.png
Β
