Fault locator function - Easergy P3 U30
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Fault locator function - Easergy P3 U30
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P2
Back to Protection & Control
Posted: ‎2021-02-23 02:00 PM . Last Modified: ‎2023-05-30 10:01 PM
1059
In which types of MV grid regarding Neutral earthing is the fault locator function (Easergy P3) applicable?
Thanks in advance.
Easergy P3
  • Thumbnail of PowerLogic P2
    PowerLogic
    PowerLogic P2
View products (1)
  • Application cases
  • PowerLogic P3
Juha
Captain Juha Captain
Captain
Posted: ‎2021-02-28 11:27 PM
1
1055
Dear @Anonymous user,
the fault locator can be used for radially operated MV networks. For short circuit fault the network star point connection doesn't matter. It means, the fault locator can be used for all type of radially operated networks.
For earth fault distance location answer in not that simple anymore. In principle, the locator can be used for all type of network. Difficulties will arise from uncertainty of zero sequence impedance. For overhead lines the zero sequence impedance is not well know. For cable networks the zero sequence impedance is known more accurately.
BR
-juha-
Juha
Captain
1
1056
BR
-juha-
Posted: ‎2021-03-01 11:55 PM
Dear @Juha, thank you for help.
Best regards,
Hasan Muftic
