Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Protection & Control
Posted: 2020-04-16 07:25 PM . Last Modified: 2023-05-30 10:18 PM
How do we use the VDS adapter with the Maxeta VDS, please? I found some info in the SC150 installation manual but it is still not clear to us.
Kind regards,
MC
Easergy SC150-CAPA voltage input is compatible with VDS (voltage detection systems) of type LRP, LRM and LR following the IEC 61243-5 standard (maximum admissible voltage: 30 Vac LL).
From Maxeta website, it seems that their VDS falls in that category so it should work.
To connect the VDS to Easergy SC150 voltage input, process as follows:
When the MV voltage is powered, Easergy SC150-CAPA will calibrate using the output of the VDS.
If you have done all that and that you have an issue, please clarify what exactly.
Thank you
Thank you
Posted: 2020-04-24 03:48 AM
Thanks!
