Easergy P5 Error code 0x847fd3e8
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Easergy P5 Error code 0x847fd3e8
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P3
Back to Protection & Control
D_Austin
Crewman D_Austin
Crewman
Posted: ‎2022-09-09 07:23 AM . Last Modified: ‎2023-05-30 10:07 PM
2
3250
Good day
I have a demo P5 I received from a Schneider Rep which gave me the Error Code in the title when I turned it on (see below)
I do not know the history of the device, this was the first time that I have turned it on.
I found the following maintenance message in the P5 user manual which is not particularly helpful.
I did contact the rep who gave me the relay and they said they would submit my information to support.
In the mean time I'm hoping someone may know something about this error.
I attempted to connect to the relay with eSetup Easergy Pro via USB and Ethernet (after finding the IP Address using an IP Sacn), however I could not connect to the device.
I unfortunately do not know what Firmware version is installed.
My thanks in advance.
  • Thumbnail of PowerLogic P3
    PowerLogic
    PowerLogic P3
View products (1)
  • PowerLogic P5
Danilo_se
Ensign Danilo_se Ensign
Ensign
Posted: ‎2022-09-12 12:00 AM . Last Modified: ‎2022-09-12 12:22 AM
I faced the same issue for several P5 relays. It's an error that comes out when P5 is power off for a long time, The time reference is lost and the date goes back to 1970. SE L3 support provided a tool to fix the problem. So, just wait for this tool from L3 (must be used only by SE , internal use).
Tomasz_M
Lieutenant Tomasz_M Lieutenant
Lieutenant
Posted: ‎2022-09-13 12:37 AM
looks legacy issue with the old products remained not energaised for very long period of time.
Please contact CCC to get quick fix for this problem.
rgd
Tomasz
Danilo_se
Ensign
Tomasz_M
Lieutenant
rgd
Tomasz
