Easergy P3 FW 30.206 Launch Letter
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Easergy P3 FW 30.206 Launch Letter
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P2
Back to Protection & Control
PekkaHAMALAINEN
Lieutenant PekkaHAMALAINEN Lieutenant
Lieutenant
Posted: ‎2022-10-24 05:21 AM . Last Modified: ‎2023-05-30 10:01 PM
5309
Happy to share the launch letter of the Easergy P3's FW 30.206. Take your time to through the attached announcement.
The FW is in production already. Easergy Pro ver 4.2.0 is required for this FW . Release date for EP will be 10 Nov 2022.
Pekka Hämäläinen
PowerLogic P3
  • Thumbnail of PowerLogic P2
    PowerLogic
    PowerLogic P2
View products (1)
  • PowerLogic P3
PekkaHAMALAINEN
Lieutenant
Posted: ‎2022-10-25 12:27 AM
3
5287
The 5th harmonic was added in FW30.205-1 already:
FW30.205.1 release functionality
This release contains the following up-dates for the P3T32, P3M32 and P3G32 requested by regions.
• SW selectable phase CT secondary current between 1 A or 5 A. This applies to such hardware which has
5 A phase current inputs in Slot 8. They are
o E = 3L(5A) + 2Io(5/1A+1/0,2A) + 4U
o 1 = 3L(5A) + 2Io (5/1A+1/0,2A) ringlug + 4U
• Up graded and restored 5th harmonic blocking stage for the dI> stage.
• Added START signals for 87dI>, 87dI>>, 64REF dIo> and 64REF dIo>> stages. They are visible in matrix,
DNP3, IEC101, IEC103 and IEC 61850 protocols.
• Added TRIP signals of 64REF dIo> and 64REF dIo>> to IEC 103 communication protocol
Pekka Hämäläinen
PowerLogic P3
Replies 13
PaterninaEnriqu
Ensign PaterninaEnriqu Ensign
Ensign
Posted: ‎2022-10-24 06:03 AM
4
5297
Hi Pekka.
I have a question regarding the 5th harmonic blocking, which was removed in function 87. Will they be included again?
PekkaHAMALAINEN
Lieutenant
3
5288
Pekka Hämäläinen
PowerLogic P3
sesa184012_brid
Ensign sesa184012_brid Ensign
Ensign
Posted: ‎2022-11-09 10:33 PM
5243
Dear Experts,
Hope all are doing great.
Can you send me the link to download Easergy P3 FW 30.206 ?.
Thanks & BR,
Ardhanari
PekkaHAMALAINEN
Lieutenant
Posted: ‎2022-11-11 02:29 AM
5230
Here you are:  FW30.206
Pekka Hämäläinen
PowerLogic P3
huseyincokall
huseyincokall
Cadet
Posted: ‎2023-10-24 01:26 PM
Dear Expert
I couldn't download the file. I'm getting an error.Can you help me?
GHBEE
GHBEE
Cadet
Posted: ‎2024-03-04 02:14 AM
4506
Where can I find the FW30.206 file?
PekkaHAMALAINEN
Lieutenant
Posted: ‎2024-03-06 06:20 AM
4477
You mean the FW? if yes then here: 07. Firmware and Translation Files
Pekka Hämäläinen
PowerLogic P3
GHBEE
GHBEE
Cadet
Posted: ‎2024-03-06 10:54 PM
I don't have access to schnider sharepoint. Can you send me the latest firmware for P3U30 attached in email?
gustav.hallden@borlange-energi.se
mgogulnath
mgogulnath
Cadet
Posted: ‎2024-07-19 11:27 PM
Hi Mr.PekkaHAMALAINEN,
This is Gogulnath Manoharan from Saudi Arabia. We used the P3U30 & P3U20 relays in our project. We are facing issue that relays were not auto rebooting after changing the configuration. we have facing this issue in several relays. Is this issue will resolve if we updrade the firmware from V30.203 to 30.206. please share your openion to resolve this issue. If you provide firmware upgrade procedure and file will be better. My email id is mgogulnath@sepco.net.cn
tolik
tolik
Cadet
Posted: ‎2024-10-14 08:44 PM
Hi Mr.PekkaHAMALAINEN, i have a problem with authorization in microsoft (AADSTS90072: User account 'a.gyske@gmail.com' from identity provider 'live.com' does not exist in tenant 'Schneider Electric' and cannot access the application '00000003-0000-0ff1-ce00-000000000000'(Office 365 SharePoint Online) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account), please send the version FW30.206 to the mailbox: a.gyske@gmail.com
  • help
John_Archer1
Ensign John_Archer1
Ensign
Posted: ‎2024-11-16 07:10 AM
@PekkaHAMALAINEN Hello, can I use this firmware to update easergy P3? Will the 104 protocol be added after the update and will the small errors be fixed?
HARIHARAN_SOUNDRAPANDIYAN
Cadet
Posted: ‎2025-05-01 10:52 PM
Hello sir I need that firmware 30.206 or 30.208 i try solve the problem in my working location here we faced if the relay getting loss of auxiliary Supply we lost the configuration from relay and changed into default so we try once with firmware upgrade
KienDT_LSE
KienDT_LSE
Cadet
Posted: ‎2025-12-08 07:51 AM
I'm Kien from Vietnam, our project used the P3U30 Schneider relay.
I am facing an issue with the P3U30 relay running firmware version V30.208:
  • When I change settings that require a reboot, after clicking Write, the software displays the message “Rebooting Fail” I then try to power off the relay and turn it on again, but all the values I wrote are not saved.
  • When I change settings that do not require a reboot, the values can be written successfully. However, after I power off the relay and turn it on again, all the modified values are lost.
The Flash Storage Usage is 100 %.
Could you please send me the download link for firmware V30.208.
Looking forward to hearing from you.
  • help
