Our company met numerous problems while working with ETL framework version 6.2.21215.01, plugin version 6.1.0.0 on Windows Server 2019 Standard Evaluation build 17763.rs5_release.180914-1434. ETL fails to extract data from PSO v.2024, seemingly, there's no errors in any log. PSO uses default windows server settings which establishes PO installer itself and has 34 custom tags for communicating with single device. Also, ETL fails to map the device via "Load Sources" button, allowing device to map seemingly on random after several times reloading ETL without making change to nothing.
Dear @Hryhorenko_ActiVolt , please note Ecostruxure Power Operation and Ecostruxure PME are not part of the portfolio managed within this community of Protection & Control, my apologies. I am sharing with you the links to both EPO and PME communities. Thanks to post your request there, our colleagues will be able to help you.
EPO -> EcoStruxure Power & Grid - Schneider Electric Community
PME -> EcoStruxure Power & Grid - Schneider Electric Community
