Certificate for VIO modules
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Certificate for VIO modules
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
Milica_Repac
Lieutenant JG Milica_Repac
Lieutenant JG
Posted: ‎2020-07-22 01:04 AM . Last Modified: ‎2023-05-30 10:01 PM
1545
Dear all,
Is there type test certificate for VIO 12AB and VIO 12AD modules?
Thanks in advance.
  • PowerLogic P3
Posted: ‎2020-07-27 06:36 AM
Hi the community members can you help this member on this topic, please?
@HenriGRASSET or @DenisParnaland do you think you can advise on this topic?
Replies 4
Milica_Repac
Lieutenant JG
Posted: ‎2020-08-26 01:40 AM
Hello everyone again,
I've a few questions considering VIO modules VIO12AB and VIO 12AD.
1. Is there any kind of type test for these VIO modules with a list of applicable standards for them?
2. If that isn't possible, is there some kind of SE statement letter that can be used to prove that VIO modules are indeed part of Easergy P3 relays and therefore standards that are listed in type test for Easergy P3 relays are also applicable for VIO modules?
3. I only found some old certificate of compliance for VIO modules issued to VAMP LTD. Is there some kind of SE statement letter in which is said that VAMP LTD is now part of Schneider Electric?
If someone has document that can prove any of this, please post it. I urgently need it.
Thanks.
Tags (3)
  • Easergy P3
  • VIO modules
Juha
Captain Juha Captain
Captain
Posted: ‎2020-09-01 06:21 AM . Last Modified: ‎2020-09-01 06:21 AM
1501
Unfortunately there is no type test report available for accessories like VIO.
BR
-juha-
Tags (2)
  • Easergy P3
sesa57670_bridg
Crewman sesa57670_bridg Crewman
Crewman
Posted: ‎2020-09-15 05:22 AM
@Juha
( @Araceli_Monje ;  @PekkaHAMALAINEN ; @HenriGRASSET )
Thank you for your reply.
From Vamp Technical Support / Anssi Häkkinen, case Case # 71956262 we got UL_Certificate_of_compliance_for_VIO12_models.pdf, see attachment.
Questions:
1. This is old certificate (attached) of compliance for VIO modules issued to VAMP LTD. Idea is to use it for P3.
2. Also, is there some kind of SE statement letter that can be used to prove that VIO modules are indeed part of Easergy P3 relays and therefore standards that are listed in type test for Easergy P3 relays are also applicable for VIO modules?
BR
Dusan
Tags (3)
  • p3
  • UL_Certificate_of_compliance_for_VIO12_models.pdf
