C264 RTU
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • C264 RTU
Araceli_Monje
Araceli_Monje Mentor
60
Arun-kumar_PS
Arun-kumar_PS Mentor
26
JuanRayo
JuanRayo Mentor
24
Back to Protection & Control
ansmehmood
ansmehmood
Explorer
Posted: ‎2025-09-03 04:04 AM
468
C264 RTU
Hi, C264RTU are installed at our site. Our plant was designed to communicate with power line carrier PLC Siemens Power Link 50/100 through IEC-101 protocol. For this we need ECU201 to establish communication between C264R and Powerlink 50/100.
Will this extended module be able to establish communication between C264R and Siemens Power Link 50/100? We had 8520A module to convert rs232 to rs485 at rtu end and from rs485 to rs232 at plc end but as per my information, Schneider device c264 only communicates through its own hardware i-e ECU201.
  • Application cases
  • MiCOM range
Araceli_Monje
Mentor
Posted: ‎2025-09-15 05:44 AM
Hi @ansmehmood , please note C264 is not an offer managed inside this Protection & Control Exchange Community, my apologies. Could you please connect with Emmanuel Gonzalez (emmanuel.gonzalez@se.com)?. He is Global Offer Marketing Owner for C264 and will be able to help you directly or connect you with the right people that are able to help with these questions.
Araceli_Monje
Mentor
