We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
PowerLogic P5, P7: ATS with MV CB (alternative with MV LBS: PowerLogic T300)
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic P5, P7: ATS with MV CB (alternative with MV LBS: PowerLogic T300)
Araceli_Monje
Lt. Commander Araceli_Monje Lt. Commander
23
HenriGRASSET
Captain HenriGRASSET Captain
14
Rudolf_Simon
Commander Rudolf_Simon Commander
13
Back to Protection & Control
sesa211247_brid
Lieutenant sesa211247_brid Lieutenant
Lieutenant
Posted: ‎2024-05-03 07:29 AM . Last Modified: ‎2025-05-26 12:28 AM
1468
Dear Expert community
is there any plan to develop an ATS (Automatic Transfert Switch)  or ABT (Automatic Bus Transfert) Application  similar to the one sold by NR PCS-9651
https://www.nrec.com/en/web/upload/2019/05/08/15572827837172kuwwm.pdf
they are a lot of opportunities in the Oil and Gas segment that require a such device
this could be done on the Powerlogic P5 (P5T32) or P7 platform
if a such product is developed it will save a lot of time, money, efforts and reduce risks .
Hope this will be done
  • Application cases
  • IEC61850
  • PowerLogic P5
  • PowerLogic P7
  • PowerLogic T300
Tags (4)
  • P5 ATS
  • P7 ATS
  • T300 ATS
sesa211247_brid
Lieutenant
Posted: ‎2024-05-10 04:35 AM
Thank You @Jinlei_Xing
Replies 8
Jinlei_Xing
Commander Jinlei_Xing Commander
Commander
Posted: ‎2024-05-07 10:56 PM
3
1375
It's a good idea to have dedicated device for both ATS and High Speed Transfer, such as ABB SUE3000 and Siemens 7VU68. It is possible to develop such a device based on the existing P7 platform.
 Currently we have one product Micom P84H which is for High Speed Transfer, but this product is only for Chinese marking.
BR,
Jinlei XING
BR,
Jinlei XING
sesa211247_brid
Lieutenant
Posted: ‎2024-05-09 01:02 AM
1352
Thank You for your feedback @Jinlei_Xing
could you share some document on the Micom P84H please (datasheet and user manual) ?
Thank you
Jinlei_Xing
Commander
Posted: ‎2024-05-09 01:17 AM
1
1346
The related P84H slides are attached.
BR,
Jinlei XING
sesa211247_brid
Lieutenant
Stefan_Scharf
Ensign Stefan_Scharf Ensign
Ensign
Posted: ‎2024-08-16 12:10 AM
The ATS function is planned in a later wave for P7 as a dedicated application function block, probably with wave 4 but it can be achieved already using the Fast scheme logic (FSL) & matrix together with a sufficent number of CT/VT inputs.
DMayberry
DMayberry Cadet
Cadet
Posted: ‎2024-08-19 07:00 AM
1
1066
In the US,  Digital Power has developed these Auto Throw-Over (ATO) applications for the P5 using the imbedded IsaGraf logic engine.  These applications are being used for MV gear standard ATO systems (MM, MTM, MG, MTG) as well as the foundation for Digital Power's more complex solutions.
sesa211247_brid
Lieutenant
Posted: ‎2025-02-20 12:47 PM
Hello, any update about this application?
could you share the documentation and settings files ?
TomBerry
Lieutenant JG TomBerry Lieutenant JG
Lieutenant JG
Posted: ‎2025-02-21 07:55 AM
The T300 HU250 module has a built-in ATS function intended for distribution network operation
With SC150 modules, this can operate switches within 300ms of voltage loss.
It is feasible to create a different configuration that communicates with protection relays instead.
This is a heading
