rm6 lever indication
  • Power Distribution IEC
  • rm6 lever indication
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
RM6
Arttu
Crewman Arttu Crewman
Crewman
Posted: ‎2025-07-09 03:57 AM
671
Is it possible to get indication of the operating Lever when it is in place?
I believe it moves the contact S1?
But the problem is can it be easily taken outside the motor unit or does it need some extra wiring?
  • Medium Voltage
  • Power Grid
Romain_Polette
Kirk Romain_Polette Kirk
Kirk
Posted: ‎2025-07-10 02:26 AM . Last Modified: ‎2025-07-10 11:10 PM
Hello @Arttu ,
All indicator contacts are available on the Customer Junction Block available on the PCB.
S1 is not directly available and not related to Operating Lever presence. It seems not possible to have Operating Lever presence indication on RM6 (only mechanical interlocking).
Romain POLETTE
Solution Architect - France Operations
Replies 5
Romain_Polette
Kirk
Posted: ‎2025-07-09 04:22 AM
668
Hi @Arttu ,
Check if you have this kind of connector on the top of your cubicle motor.
Romain POLETTE
Arttu
Crewman
Posted: ‎2025-07-09 04:32 AM
In response to Romain_Polette
But thats from SM6, in RM6 it is close to that but not quite the same.
Romain_Polette
Kirk
Posted: ‎2025-07-10 12:15 AM . Last Modified: ‎2025-07-10 12:21 AM
Hello @Arttu ,
I have no picture of RM6, but this is similar.
You need to remove the top cover of the RM6 and the Terminal Block mounted on a PCBA will be available.
Please refer to the RM6 operation manual for more information.
Check also this document:
https://download.schneider-electric.com/files?p_Doc_Ref=07897227FE&p_enDocType=User+guide&p_File_Nam...
Romain POLETTE
Arttu
Crewman
Posted: ‎2025-07-10 01:58 AM
How is this a solution to my original question?
Romain_Polette
Kirk
Hello @Arttu ,
Romain POLETTE
