>630A MCCB with 90C cables without derating.
  • Power Distribution IEC
  • >630A MCCB with 90C cables without derating.
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
dhrobertson
Crewman dhrobertson
Crewman
Posted: ‎2024-06-05 02:00 AM
1605
I am advised that NS800 MCCB can be handle 90C directly without derating. Please confirm.
Gregoire_Brun
Commander
Posted: ‎2024-06-13 07:28 AM
1527
hello @dhrobertson
Reference temperature for a Compact NS is 40°C (inside equipment), you can use 90°C Cable like 75°C cable, it don't change anythink,  You should to respect this derating table as advise. and you must to confirm the temperature respect on diferent points ( connection, frotn face , handle) in conformity with IEC 61439 internationnal standard
Best regards
Gregoire Brun
Breaker Product Expert
Replies 4
dhrobertson
Crewman dhrobertson
Crewman
Posted: ‎2024-06-12 10:55 PM
No comments! extraordinary!
Gregoire_Brun
Commander
1528
hello @dhrobertson
Best regards
Gregoire Brun
dhrobertson
Crewman dhrobertson
Crewman
Posted: ‎2024-06-13 10:33 PM
In response to Gregoire_Brun
Thank you M. Brun! In this case we have an NS800 with Ir = 0.8 x 800= 640A connected to bus bars on the input side and 1.5m of copper bus bars on the output side connected to a single set of 400mm2 XLPE cables. There are 34 sets of these installed. The enclosure is from 4B, ventilated, and the entire pod is cooled by CRAC to 25-28C. I understand the 75C max rating but will run a full load test and carry out a thermographic analysis. Your response and the tables provided are much appreciated!
Gregoire_Brun
Commander
Posted: ‎2024-06-13 11:47 PM
 with pleasure @dhrobertson
take tyime to check this 2nd table
For 640A section of 400mm² looks a little low, please check internal temp inside your equipment.
When we check temp on breaker in accordance with IEC 60-947-2, we use 500mm² sections at 800A and 400mm² at 630A.
Best regards
Gregoire Brun
