contact resistance
  • Power Distribution IEC
  • contact resistance
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
75
J_Travostino
Sisko J_Travostino Sisko
70
S-W
Commander S-W Commander
67
simon00011
Crewman simon00011
Crewman
Posted: ‎2025-02-12 09:10 AM
1950
contact resistance
which code/industry standard shows bus-to-lug acceptable contact resistance for 1KV switchgear used in Canada or US?    Thanks!
  • Power Standards & Regulations
Chris1969
Crewman Chris1969 Crewman
Crewman
Posted: ‎2025-02-22 06:20 AM
I'm not aware of a standard outside of any specific manufacturer recommendations. A lot of variables determine the actual value measured. For high ampacity conductors with highly conductive contact surfaces, measurements in single digit micro-ohms is the goal.
ANSI-NETA ATS and MTS provide procedures for visual and mechanical inspections, and electrical tests for finding high resistance connections in electrical systems, and specifically bolted electrical connections. There are also explanations of acceptable test values. From the ANSI/NETA MTS 2015 edition, reference 7.1.A.7 and 7.1.B.1 and 7.1.C.1 and 7.1.D.1.
Replies 7
Gregoire_Brun
Commander
Posted: ‎2025-02-14 02:23 AM
hello @simon00011
Did you have this needed for a dedicated product?
It should be good to share with us a product reference.
Gregoire Brun
Breaker Product Expert
simon00011
Crewman simon00011
Crewman
Posted: ‎2025-02-14 08:49 AM
Hello @Gregoire_Brun
Please see below 2 pictures of nameplates for 2 switchboards installed in Toronto, Canada. Can you please advise the busbar-to-lug contact resistance for 2 switchboards respectively?   Thanks!
1600A 600V4000A 208V
Gregoire_Brun
Commander
Posted: ‎2025-02-18 12:06 AM . Last Modified: ‎2025-02-18 12:07 AM
1870
@simon00011 , I'm sorry. I can't see your pictures
Gregoire Brun
simon00011
Crewman simon00011
Crewman
Posted: ‎2025-02-20 05:47 AM
In response to Gregoire_Brun
@Gregoire_Brun
Can you see 2 attached pictures?
Gregoire_Brun
Commander
Posted: ‎2025-02-20 11:59 PM
1839
hello @simon00011 yes I see them now.
So if I understand well, it's some panel board make by schneider / Square D
Is it possible to have a global vue of the panel, please ?
thanks
Gregoire Brun
simon00011
Crewman simon00011
Crewman
Posted: ‎2025-02-21 11:21 AM
@Gregoire_Brun
these are Schneider/Square D low voltage switchboard 347/600V/3PH/4W and 120/208V/3PH/4W respectively, installed in Toronto, Canada. unfortunately, global vue is available.
Chris1969
Crewman
