EcoDial 5.3.1
  • Power Distribution IEC
  • EcoDial 5.3.1
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
LarisaFranco
Crewman LarisaFranco Crewman
Crewman
Posted: ‎2025-01-10 11:30 AM
5
1692
EcoDial 5.3.1
Hi
Can you advise what are the release notes for version 5.3.1?
Also please indicate how customers can download new version
Thanks!
  • Software
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2025-01-15 09:26 AM
1
1615
Hi Larisa,
Thank you for reaching out to us!
Please find attached the release notes for INT 5.3.0, which are also applicable to the INT 5.3.1 version.
Since INT 5.3.1 is a patch release, there are no separate release notes for it.
The patch fix primarily addresses the cable crash issue.
You can upgrade the version by SESU update
Or download through this link https://www.se.com/in/en/product-range/61013-ecostruxure-power-design-ecodial/#overview.
If you have any further questions, feel free to ask!
Thanks & Regards,
Team- Ecodial Expert support.
Replies 5
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-01-13 12:25 AM
Hello @LarisaFranco, thank you for your question, we'll come back to you!
Saravanakumar.L
Lieutenant
1
1616
Hi Larisa,
Thanks & Regards,
LarisaFranco
Crewman
Posted: ‎2025-01-16 04:50 AM
In response to Saravanakumar.L
Thanks!
dozelprod
dozelprod
Cadet
Posted: ‎2025-02-20 01:33 AM
1388
Hi, I just installed the last version 5.3.1 and when I try to lunch the application is not working, could be an issue with Edge browser? Thanks.
dozel
Saravanakumar.L
Lieutenant
Posted: ‎2025-02-20 10:12 PM . Last Modified: ‎2025-02-20 10:14 PM
In response to dozelprod
Hello Dozelprod,
Thanks for reaching us
Kindly share the below files to analyze the issue.
  1. Screenshots related to any error message.
  2. Needs to check .NET 3.5 framework is enabled or not?
  3. System configuration
  4. Log file- Please get the log files by using below mentioned path. During opening and login, the application. 1214.png
Thanks & Regards,
