What does "upstream" and "downstream" mean in a circuit breaker?
  • Power Distribution IEC
  • What does "upstream" and "downstream" mean in a circuit breaker?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2021-03-13 01:56 AM
9
33767
I have seen several times the words "upstream" and "downstream" related to circuit breakers.
Can someone explain me simply and clearly what these mean?
Is there any difference with supply & load for circuit breaker?
Sorry if this question may seem a little weird to you .... 😊 😁
Thanks a lot.
  • How to
  • Products
Posted: ‎2021-03-13 03:52 AM
7
33746
In Electrical Distribution, upstream and downstream refers to "Incoming" and "outgoing" circuit breakers.
Regarding your question on supply and load of circuit breaker, there is no supply side and load side in present circuit breakers
and supply and load connections  can be reversed. In Earlier circuit breakers, there was specific marking on circuit breaker i.e.
terminals were marked with Supply or Load side, Technology has progressed and these connections can be reversed.
Hope I answer your question.
Thanks.
RHH
Commander | EcoXpert Master RHH Commander | EcoXpert Master
Posted: ‎2022-02-01 12:32 PM . Last Modified: ‎2022-02-01 12:42 PM
In response to Anonymous user
1
31494
Hello @Anonymous user
The breakers with those limitations have the indications on the devices.
Breakers who dont have this do not show this indication as it is not necessary.
As far as I know;
The breakers who can have these limitations are mostly breakers like;
An GFCI Circuit breaker - Ground-Fault circuit interruptor
An AFCI/D Circuit breaker - Arc-Fault circuit interruptor/detector
Why are those limitations especially on these breakers? Because they have an extra security build in where they have to react/trip/turn off to.
With this security in the products they are more susceptible to damage or fault-trips if they are connected reversed.
At last, the picture you ask about how it can be marked below;
Sometimes it is shown on a label on the breaker as well; No reverse feeding!
But like the previous answer; You barely see this anymore as the fabrication of breakers have evolved with the years.
Hope this is of any help to you!
Kind regards,
Rick
Gregoire_Brun
Commander
Posted: ‎2022-02-02 11:28 PM . Last Modified: ‎2025-08-12 05:13 AM
1
31459
hello
It's due to some performance limitation in some products to respect performance during short circuit test.
It's the case for Compact NSX R, HB1, HB2 (690V application and the new NSX400K (1000V Application)
I will see to find some pictures to find equivalent picture shared by RHH-Eltechna
Best regards
Gregoire Brun
Breaker Product Expert
Replies 9
J_Travostino
Sisko
Posted: ‎2021-03-13 02:03 AM
Do not worry. There is no "stupid" question.
Someone from our community will surely be able to answer you on this..... 😉
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
7
33747
Thanks.
Posted: ‎2021-03-13 09:29 AM
33738
Thank you @Anonymous user for your quick answer.
Gregoire_Brun
Commander
Posted: ‎2022-02-01 07:18 AM . Last Modified: ‎2022-02-01 07:20 AM
31521
On catalogue we speak about some limitation sometime about reverse feeding ( for some high perf breaker)
And we indicate on the breaker if it have limitation the "line" side for upstream and "load " side for downstream
Gregoire Brun
Posted: ‎2022-02-01 07:47 AM
In response to Gregoire_Brun
31513
Thank you @Gregoire_Brun for these complementary information.
What are the criteria for these limitations?
Which products are concerned?
What do you mean "we indicate on the breaker"? I guess it is like some marking but can you confirm and eventually post a picture?
RHH
1
31495
As far as I know;
Kind regards,
Rick
Posted: ‎2022-02-01 11:37 PM
In response to RHH
Thank you @RHH for sharing information.
Gregoire_Brun
Commander
1
31460
hello
Best regards
Gregoire Brun
Posted: ‎2022-02-03 12:58 AM
Thanks @Gregoire_Brun
