84400members
353588posts
What does "upstream" and "downstream" mean in a circuit breaker?
T_Parks
Lieutenant
Lieutenant
I have seen several times the words "upstream" and "downstream" related to circuit breakers.
Can someone explain me simply and clearly what these mean?
Is there any difference with supply & load for circuit breaker?
Sorry if this question may seem a little weird to you .... 😊 😁
Thanks a lot.
T_Parks
Kiran_Lagwankar
Ensign Ensign
Re: What does "upstream" and "downstream" mean in a circuit breaker?
In Electrical Distribution, upstream and downstream refers to "Incoming" and "outgoing" circuit breakers.
Regarding your question on supply and load of circuit breaker, there is no supply side and load side in present circuit breakers
and supply and load connections  can be reversed. In Earlier circuit breakers, there was specific marking on circuit breaker i.e.
terminals were marked with Supply or Load side, Technology has progressed and these connections can be reversed.
Hope I answer your question.
RHH-Eltechna
Commander | EcoXpert Master Commander | EcoXpert Master
Hello @T_Parks
The breakers with those limitations have the indications on the devices.
Breakers who dont have this do not show this indication as it is not necessary.
As far as I know;
The breakers who can have these limitations are mostly breakers like;
An GFCI Circuit breaker - Ground-Fault circuit interruptor
An AFCI/D Circuit breaker - Arc-Fault circuit interruptor/detector
Why are those limitations especially on these breakers? Because they have an extra security build in where they have to react/trip/turn off to.
With this security in the products they are more susceptible to damage or fault-trips if they are connected reversed.
At last, the picture you ask about how it can be marked below;
Sometimes it is shown on a label on the breaker as well; No reverse feeding!
But like the previous answer; You barely see this anymore as the fabrication of breakers have evolved with the years.
Hope this is of any help to you!
Kind regards,
Rick - Eltechna B.V.
signature-RHHH
Gregoire_Brun
Lt. Commander Lt. Commander
hello
It's due to some performance limitation in some products to respect performance during short circuit test.
It's the case for Compact NSX R, HB1, HB2 (690V application and the new NSX400K (1000V Application)
I will see to find some pictures to find equivalent picture shared by RHH-Eltechna
Best regards
9 Replies 9
J_Travostino
Admiral Admiral
Admiral
Hello @T_Parks
Do not worry. There is no "stupid" question.
Someone from our community will surely be able to answer you on this..... 😉
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
Kiran_Lagwankar
Ensign Ensign
T_Parks
Lieutenant
Lieutenant
5817
Thank you @Kiran_Lagwankar for your quick answer.
T_Parks
Gregoire_Brun
3600
Hello @T_Parks
On catalogue we speak about some limitation sometime about reverse feeding ( for some high perf breaker)
And we indicate on the breaker if it have limitation the "line" side for upstream and "load " side for downstream
T_Parks
Lieutenant
Lieutenant
3592
Thank you @Gregoire_Brun for these complementary information.
What are the criteria for these limitations?
Which products are concerned?
What do you mean "we indicate on the breaker"? I guess it is like some marking but can you confirm and eventually post a picture?
T_Parks
RHH-Eltechna
Hello @T_Parks
As far as I know;
Kind regards,
signature-RHHH
T_Parks
Lieutenant
Lieutenant
Thank you @RHH-Eltechna for sharing information.
T_Parks
Gregoire_Brun
hello
Best regards
T_Parks
Lieutenant
Lieutenant
Thanks @Gregoire_Brun
T_Parks
