Using cicode functions to control breakers
  • Power Distribution IEC
  • Using cicode functions to control breakers
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
AnaDimitrievska
AnaDimitrievska Cadet
Cadet
Posted: ‎2024-09-12 07:06 AM
835
I want to write a script to automate multiple breakers to switch on and off for validation and testing. I have been able to export the tag names into a file, and generate a script for the "Test Script" tool in ctApi. This works, but is a bit tedious.
I am wondering if it is possible to write a cicode function that will be able to do this for me? I attempted the following as a test, and although I was able to run it in the Test Script, it did not open or close the breaker on the animation.
However, the following, which seems more useful to me, refused to run at all.
Overall results:
However, neither function actually works.
Is there a better way to do this? Or a different way to call the function?
Any help is appriciated.
Romain_Polette
Kirk Romain_Polette Kirk
Kirk
Posted: ‎2024-09-23 07:34 AM
Hello @AnaDimitrievska ,
Better ask on this forum:
https://community.se.com/t5/EcoStruxure-Power-Operation/bd-p/power-scada-operation
Romain POLETTE
Solution Architect - France Operations
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2024-09-20 05:33 AM
Hello @AnaDimitrievska , thank you for your message, we'll come back to you for the answer!
Romain_Polette
Kirk
Romain POLETTE
