Tutorial: How to size a transformer for industrial loads?
  • Power Distribution IEC
  • Tutorial: How to size a transformer for industrial loads?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-07-09 01:15 AM . Last Modified: ‎2025-07-09 01:17 AM
Correctly sizing a transformer is essential for ensuring reliable power delivery, avoiding overloads, and planning for future expansion.
Follow this step-by-step guide to determine the right transformer size for your industrial application.
Step 1: list all electrical loads
Start by identifying all the equipment that will be powered by the transformer. For each item, note:
  • Power rating (in kW, kVA, or HP)
  • Voltage
  • Phase (single or three-phase)
  • Operating current (if available)
Step 2: convert all loads to kVA
Transformers are rated in kVA, so convert all loads accordingly:
  • For three-phase loads:
    kVA = (√3 × Voltage × Current) / 1000
  • For single-phase loads:
    kVA = (Voltage × Current) / 1000
If you only have kW and power factor (PF): kVA = kW / PF
Step 3: apply demand and diversity factors
Not all equipment runs at full load all the time. Apply:
  • Demand factor: reflects the actual maximum load expected.
  • Diversity factor: accounts for the probability that not all loads operate simultaneously.
Example:
If your total connected load is 500 kVA and the demand factor is 0.8:
Actual load = 500 × 0.8 = 400 kVA
Step 4: add a safety margin
To allow for future expansion and avoid overloading, add a safety margin of 10–25%.
Example:
Required transformer size = 400 × 1.2 = 480 kVA
Step 5: select the nearest standard transformer size
Choose the next standard transformer size above your calculated requirement.
Common sizes include: 25, 50, 75, 100, 150, 200, 300, 500, 750, 1000 kVA, etc.
In the example above, you would choose a 500 kVA transformer.
Step 6: match voltage levels
Ensure the transformer’s:
  • Primary voltage matches the utility supply
  • Secondary voltage matches your equipment requirements
Step 7: consider additional factors
  • Cooling type: dry-type (indoor) or oil-immersed (outdoor)
  • Impedance: affects short-circuit current levels
  • Efficiency: higher efficiency reduces energy losses
  • Environmental conditions: temperature, humidity, altitude, etc.
In conclusion, proper transformer sizing is essential for ensuring safe, efficient, and reliable power distribution in industrial settings. By calculating the total load, applying realistic demand factors, and including a safety margin, you can confidently select a transformer that meets both current and future needs. Always match voltage levels and consider environmental and operational factors to ensure long-term performance.
  • How to
  • Knowledge
Replies 0
