Thermal Monitoring with CL 110 for I-Line II busway
  • Power Distribution IEC
  • Thermal Monitoring with CL 110 for I-Line II busway
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Hyeontae-Song
Ensign Hyeontae-Song
Ensign
Posted: ‎2022-01-11 03:52 AM
2972
I want to use CL110 for I-Line II busway.
Is the temperature difference between the upper/lower part (AL) and the side (FE) of the busway enclosure a lot?
Best Regards
  • Power Availability
  • Safety - People Safety
AreejSakr
Crewman AreejSakr Crewman
Crewman
Posted: ‎2022-01-11 04:31 AM
Hi Song,
This is Areej Sakr the PO for canalis HP busway, i would like to draw your attention that CL110 is recommended to be used at the Junction blocks as it's the most critical parts and the most to indicate any critical thermal performance for busway, for I-line II there's a certain brackets to be used to install the CL110 on the JB, let me know if you have any questions, I would also recommend you contact your local support for more information on the installation,
thanks,
Areej Sakr
Global Diffuse Channel Manager
J_Travostino
Sisko
Posted: ‎2022-01-11 07:22 AM
2955
Hello @Hyeontae-Song,
to complement @AreejSakr's answer above, looking at the CL110 User Guide, it appears that we recommend to put it on the surface that is parallel to the conductors (see extract below).
 You could find the user guide for CL110 here.
Hope it also helps.
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
PascalL
PascalL Schneider Alumni (Retired)
Posted: ‎2022-01-17 06:05 AM
In response to J_Travostino
Regarding the question, I think the installation on this type of busway is possible take into account the explinations already proposed. In compact busbar trunking (Iline) systems, the enclosure is in contact with the insulated conductors. This sensor is usually installed to the most thermal contrained point and this one is the junction block connection. It is recommanded to install the sensors on the side of the onclosure close to the junction block. See the diagramm on the file attached. Best regards,
Pascal Lepretre.
Replies 4
AreejSakr
Crewman
Hi Song,
thanks,
Areej Sakr
J_Travostino
Sisko
2956
Hope it also helps.
Julien Travostino
Power Products Div.
PascalL
Pascal Lepretre.
malappa
Crewman malappa Crewman
Crewman
Posted: ‎2024-01-19 08:34 AM
Hi @J_Travostino ,What is the accuracy and temperature measurement range of the CL110? Also, what is the abnormal temperature limit for the busway?"
