The wiring diagram of Ground Fault Detection in case multi-source, one grounding ACB 3 Pole (using RS method)
  • Power Distribution IEC
  • The wiring diagram of Ground Fault Detection in case multi-source, one grounding ACB 3 Pole (using RS method)
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
MasterPact MTZ
Wittawas
Wittawas
Cadet
Posted: ‎2023-06-03 09:02 AM
2
1913
I have looked in Ground Fault  Protection Low voltage expert guides n° 2  https://download.schneider-electric.com/files?p_enDocType=Technical+leaflet&p_File_Name=DBTP140GUI_E... and
I would like to install ground fault detection for our system to comply with 4.1.1.3 Study 2 Diagram 3.
as below
and the description is
which I still don't know how to sum neutral current when tie bus is on.
Could you please recommend me how to connect NCT and ACB status contact diagram to achieve 4.1.1.3 Study2 Diagram3.
Thank you
  • How to
S-W
Commander S-W Commander
Commander
Posted: ‎2024-10-10 01:08 AM
@Wittawas , pardon for the delayed response. Thank you for your message and patience, we'll come back to you!
Hundred9
Hundred9
Cadet
Posted: ‎2025-10-14 08:13 PM
@Wittawas @S-W
Hi, I’m facing the same issue.
Could you please recommend me how to connect the NCT (Neutral Current Transformer) and the ACB status contacts in the ground fault detection circuit?
A simple wiring diagram or example would be very helpful.
Thank you in advance!
