Audible noise on Trihal transformer
  • Power Distribution IEC
  • Audible noise on Trihal transformer
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Trihal
TDHai_SE
TDHai_SE Cadet
Cadet
Posted: ‎2025-10-09 07:25 PM
376
Dear Expert team,
Our customer using Trihal Cast Resin dry type transformer 1600 kVA, and the apartment just use with load only 100A but on the transformer, the audible noise measured about 70-75db vs catalogue 57db at 1m.
Can any one expertise on Traihal Transformer can support us some suggestion how to investigate or do we have any more solution to reduce the noise on the transformer.
Because the transformer installed near apartments so residents reacted very strongly about the noise
Thank you
  • Power Grid
Gregoire_Brun
Commander
Posted: ‎2025-10-13 12:11 AM . Last Modified: ‎2025-10-14 12:12 AM
Hello @TDHai_SE
I'm not from Traihal Transformer department.
Even as you know , electrical product create magnetic force witch can cause metalic part vibration. so it can explain the reason of the noise.
I can understand this noise is not acceptable by residents , i would suggest to call your local helpdesk to have a field service intervention.
Gregoire Brun
Breaker Product Expert
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-10-10 06:32 AM
Hello @TDHai_SE, thank you for your post, we'll come back to you!
Gregoire_Brun
Commander
Hello @TDHai_SE
Gregoire Brun
