The new release : EcoStruxure Power Design - Ecodial INT 5.2.0
  • Power Distribution IEC
  • The new release : EcoStruxure Power Design - Ecodial INT 5.2.0
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
Genghiz
Captain
Posted: ‎2024-05-07 04:31 AM . Last Modified: ‎2024-11-22 04:25 AM
3348
Hello All,
There is a new release made available for the "EcoStruxure Power Design - Ecodial" as an  International version 5.2.0.
It is released on 6th May and notified to all existing users through SESU (Schneider Electric Software Update).
What is new?
  1. MasterPacT MTZ - MicroLogic Active (Orion)
  2. Reference Design
From the following link, the latest version is available for download.
Country Selector | Schneider Electric Global
The selection of 'reference project' is shown as follows from...'Open an existing project.'
The selection of 'MasterPacT MTZ with MicroLogic Active' is shown as follows from...'The entire catalogue' option.
Thanks for your attention.
Team - Ecodial Expert Support.
  • Power Distribution Software
EDBAS
Crewman EDBAS
Crewman
Posted: ‎2024-06-04 12:58 AM
The diversity factor issue is still not resolved in this update. We hope that this will be considered in the next update.
EDBAS
Crewman EDBAS
Crewman
Deathstroke
Deathstroke
Cadet
Posted: ‎2025-07-14 03:24 AM
1068
Hi...
I need help about Low Voltage Distribution Board (TGBT). I want to realize a TGBT for:
3 blocks of 17 Cooling Chamber CC-1 to CC-17, each one equipped with Condensation group (CG) and Evaporator (EV)
Block-1
CC-1 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 140m
CC-2 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 140m
CC-3 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 140m
CC-4 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 140m
Block-2
CC-5 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 130m
CC-6 (CG 23kW + EV 2kW / 400V 3P+N) Cable length to TGBT = 130m
CC-7 (CG 23kW + EV 2kW / 400V 3P+N) Cable length to TGBT = 130m
CC-8 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 130m
Block-3
CC-9 (CG 11.5kW + EV 1.5kW / 400V 3P+N) Cable length to TGBT = 130m
CC-10 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 130m
CC-11 (CG 28kW + EV 4kW / 400V 3P+N) Cable length to TGBT = 130m
CC-12 (CG 32kW + EV 5kW / 400V 3P+N) Cable length to TGBT = 130m
CC-13 (CG 32kW + EV 5kW / 400V 3P+N) Cable length to TGBT = 130m
CC-14 (CG 31kW + EV 5kW / 400V 3P+N) Cable length to TGBT = 130m
CC-15 (CG 31kW + EV 5kW / 400V 3P+N) Cable length to TGBT = 130m
CC-16 (CG 54kW + EV 6kW / 400V 3P+N) Cable length to TGBT = 130m
CC-17 (CG 50kW + EV 6kW / 400V 3P+N) Cable length to TGBT = 130m
01 Residential building (20kW / 400V 3P+N) Cable length to TGBT = 130m
01 Submersible pump (5kW / 400V 3P+N) Cable length to TGBT = 130m
20 Outdoor lighting lamps (150W each / 220V Monophasic) Cable length to TGBT = 130m
02 Spares (28kW, 50kW / 400V 3P+N) EXPECTED Cable length to TGBT = 130m
Each Cooling item should have a separate Circuit Breaker. I designed the whole system in Ecodial but results are confusing me. For example Circuit Breaker for CC-1 proposed by Ecodial is 25A however the circuit breaker existing the CC-1 distribution board is 40A.
Note that the whole system is power supplied from 630kVA transformer 30kV/400V protected with existing ABB 1000A (Without RCD) circuit breaker.
Please can you help me to design the correct SLD for the whole system, and advise me with the correct equipment that I should install on this TGBT? Note that all the equipment that I will use is brand Schneider.
Thank you in advance,
Darini
Lieutenant JG Darini Lieutenant JG
Lieutenant JG
Posted: ‎2025-07-22 06:46 AM
In response to Deathstroke
Hi!
i have created a simple SLD with your requirements in Ecodial and I have shared with you the .eac file. Please feel free to reach out if you have any other queries.
cooling chamber_design.eac
