How to design a low voltage distribution board?
  • Power Distribution IEC
  • How to design a low voltage distribution board?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-07-24 02:06 AM . Last Modified: ‎2025-07-24 02:08 AM
Designing a low voltage distribution board (LVDB) involves careful planning to ensure safety, reliability, and compliance with electrical standards.
You can find here a step-by-step guide to help you through the process.
Step 1: Define the requirements
  • Determine the voltage level (e.g., 230V single-phase or 400V three-phase).
  • Identify the types of loads (lighting, sockets, HVAC, motors, etc.).
  • Calculate the total power demand (in kW or kVA).
  • Decide on the number of circuits needed.
Step 2: Choose the enclosure
  • Select the material (metal or plastic).
  • Choose the IP rating based on the environment (e.g., IP65 for outdoor).
  • Ensure the size allows for all components and future expansion.
Step 3: Select the components
  • Main Incomer: MCCB or MCB with suitable rating.
  • Busbars: rated for total current.
  • Outgoing MCBs: one for each circuit, sized to the load.
  • RCDs/RCBOs: for earth leakage protection.
  • Surge Protection Device (SPD): optional but recommended.
  • Neutral and Earth Bars: for proper termination.
Step 4: Perform load calculations
  • Apply diversity factors to avoid oversizing.
  • Ensure the sum of outgoing breakers does not exceed the main breaker rating.
Step 5: Design the wiring and layout
  • Create a Single-Line Diagram (SLD) showing all connections.
  • Size the cables based on current, voltage drop, and installation conditions.
  • Clearly label all breakers and terminals.
Step 6: Ensure compliance with standards
  • Follow local regulations (e.g., IEC 61439, NF C 15-100 in France).
  • Ensure proper earthing and bonding.
  • Prepare documentation for inspection and maintenance.
Step 7: Testing and commissioning
  • Perform:
    • Insulation resistance test
    • Continuity of protective conductors
    • Polarity check
    • Functional testing of RCDs and breakers
In conclusion, a well-designed LV distribution board ensures safe, efficient, and compliant power distribution. Follow each step carefully to meet both technical and regulatory requirements.
  • How to
  • Knowledge
Replies 0
