Should I worry about output Ambere rating on Voltage Stabilizer
  • Power Distribution IEC
  • Should I worry about output Ambere rating on Voltage Stabilizer
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
sanda
sanda
Cadet
Posted: ‎2024-04-14 02:13 AM . Last Modified: ‎2024-11-22 04:25 AM
815
Electricity supply in my home town in so bad that it fluctuate every 30 second going down by 50 to 70 volts from standard 230V and comes back to the standard voltage at the same second. I'm using an APC UPS and it clicks all day(AVR) and it is quite annoying. I'm looking for a voltage stabilizer to use with my UPS which require 200 to 240V at 6A. But the stabilizer I found outputs 200-240 V at only 2.5 A. Is this going to be an issue? is it going to hurt my UPS and my PC. If not why?
omegle xender
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2024-04-29 03:55 AM
Hello Sanda,
Thanks for reaching the EcoStruxure Power Design Forum.
Here is the link to reach SE support page.
Contact Support | Schneider Electric Global (se.com)
Team - Ecodial Expert Support
Genghiz
Captain
Posted: ‎2024-04-15 11:22 PM . Last Modified: ‎2024-04-29 03:52 AM
Hello Sanda,
As this forum is dedicated to the ‘low voltage electrical network design software.’ We would propose you reach the global support system through the following steps.
Step 1 - https://www.se.com/myschneider/settingsAndPreferences?type=OM
(User can switch the country as per their location).
Step 2 – Click on Contact US option and user can choose the email option to directly create a bFO (salesforce) ticket.
Step3 – User needs to fill all the mandatory details, also can attach the required supportive files. (Like Screenshots, Catalogues…. etc.) And then click on SEND button. User will receive an e-Mail notification along with BFO ticket number.
Thank you,
Team – Ecodial Expert Support.
Genghiz
Captain
Hello Sanda,
