NS1600N withdrawable circuit breaker stab tempreture
  • Power Distribution IEC
  • NS1600N withdrawable circuit breaker stab tempreture
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-10-09 07:43 AM
1677
Good Day,
Does anyone know the temperature of the Stab on a NS1600N withdrawable circuit breaker
Christian_Bach
Lt. Commander Christian_Bach Lt. Commander
Lt. Commander
Posted: ‎2022-10-11 05:15 AM
In response to Anonymous user
1629
Good day,
The standard IEC60947-1  states 70K temp rise for silver plated connections, which is the case on NS1600, for a maximum reference temperature of 40°C around the CB :
"The ambient air temperature does not exceed +40 °C and its average over a period of 24 h
does not exceed +35 °C."
This requirement is given in free air, with the cable / bars sections stated by the standard (2 bars of 100mm x 5mm for 1600A).
Best regards,
Christian
Christian_Bach
Lt. Commander
Posted: ‎2022-10-11 06:17 AM
Maybe my message was not clear enough : the temp rise allowed is 70K on the customer connections, under the conditions of the product standard (vertical mounting, in free air with the requested cross sections).
This is for "new state" product, after tests the limit is raised to 80K as per IEC60947-2.
Replies 5
Christian_Bach
Lt. Commander
Posted: ‎2022-10-09 11:25 PM
4
1656
Good day,
Could you please clarify the points below ;
- is your question related to UL489 or IEC ?
- do you mean stabs on the circuit breaker or on the chassis busbars connection ?
Best regards,
Christian
Posted: ‎2022-10-10 03:16 AM
In response to Christian_Bach
1645
Good Day,
We are looking for the heat temperature on the stab of the NS1600N breaker as per the IEC specifications.
Christian_Bach
Lt. Commander
1630
Good day,
Best regards,
Christian
Posted: ‎2022-10-11 06:11 AM
1623
Not referring to the ambient temperature, I would like the actual temperature rise on the sub of the busbar coming out the breaker.
Christian_Bach
Lt. Commander
