MTZ Restricted Earth Fault Protection.
  • Power Distribution IEC
  • MTZ Restricted Earth Fault Protection.
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
MasterPact MTZ
Peter_Hall
Lt. Commander | EcoXpert Master Peter_Hall Lt. Commander | EcoXpert Master
Posted: ‎2021-03-20 02:50 AM
10
7235
We are seeing a big rise in the number of enquiries for battery storage systems and renewables in general. there seems to be a big push (in the UK) for earth fault protection. We cover this with the ML4 trop units on NSX and M6.0X on MTZ. However there seems to be a growing requirement to have REF protection (earth fault protection looking back into the transformer secondary winding).
Can anyone in the MTZ development team advise the time line to include this protection on the MTZ offer as previously offered on NW/NT?
  • Power Availability
  • Safety - Electrical Fire Prevention
Ludovic_Soudril
Lieutenant JG Ludovic_Soudril Lieutenant JG
Lieutenant JG
Posted: ‎2021-03-22 09:17 AM
In response to Peter_Hall
1
7200
Hi Peter,
Restricted Earth Fault is not available today on MTZ.
REF is planned to be implemented in MTZ via a dedicated Digital Module in 2022.
Today, the only solution for REF on ACB is with NW (special configuration).
Best regards
Ludovic
Replies 10
Posted: ‎2021-03-20 10:01 PM
In MTZ ACBs, Restricted Earth Fault protection is available as in MasterPact NW/NT. The terminology used is SGR (Source to Ground)protection. It involves external sensor( SGR Sensor) to measure the transformer Neutral current and MDGF Module.
Please refer our Detailed catalogue of MTZ for SGR protection.
Hope this answers your question.
Best Regards
Kiran Lagwankar
Fabien_Mastrot
Fabien_Mastrot Schneider Alumni (Retired)
Posted: ‎2021-03-22 07:05 AM
7217
Hello Peter, you meant , designing a Masterpact MTZ with a 4 poles breakers but with no protection for Neutral inside the breaker ? Thanks
Fabien Mastrot
EcoXpert global badge owner
Peter_Hall
Posted: ‎2021-03-22 07:25 AM
In response to Fabien_Mastrot
4
7216
Hi Fabien,
No, let me explain a bit clearer.
We are looking for an ACB with overcurrent protection. However we would also like to protect the cables & the transformer LV winding 'upstream' via and earth fault protection. Normally this is achieved by:
MTZ ACB with M2.0/5.0X trip unit.
Aveva (Was Alstom/GEC) MCAG14 relay with 4 x CT's, N/E link fitted downstream of the CT's (before the ACB).
Battery charger to trip the MTZ ACB Sht on relay operation.
The MCAG 14 CT's are the limit of the 'zone'. Therefore any earth fault occurring between the transformer LV winding and the CT's is detected and trips the ACB i.e. an in zone fault.
Hope that this makes sense?
Ludovic_Soudril
Lieutenant JG
Posted: ‎2021-03-22 07:58 AM
7210
Dear Peter,
Just to be 100% sure of your request.
Do you want to achieve with MTZ the same feature (Restricted Earth Fault Protection) as the one proposed with NW in the doc attached below?
Best regards
Ludovic
Peter_Hall
Posted: ‎2021-03-22 08:03 AM
In response to Ludovic_Soudril
7206
Hi Ludovic,
That is exactly the application.
Best regards,
Peter Hall.
Ludovic_Soudril
Lieutenant JG
1
7201
Hi Peter,
Best regards
Ludovic
Peter_Hall
Posted: ‎2021-03-22 09:34 AM
Hi Ludovic,
That is great. Thank you for clarifying this.
Best regards,
Peter Hall.
brettjduncan
brettjduncan
Cadet
Posted: ‎2023-02-17 08:22 PM
Hi, has this feature been included in the MTZ range yet?
regards,
Brett
Gowrishankar_Selvaraj
Gowrishankar_Selvaraj Cadet
Cadet
Posted: ‎2024-05-14 05:26 PM
Does Restricted Earth Fault protection is available in MTZ 2 series breakers now?
Gowrishankar
Ian-Johnson
Ian-Johnson
Cadet
Posted: ‎2025-10-22 06:23 AM
Have we finally got the REF function available for the MTZ range of ACB's now? (Oct 2025)
As this thread has been going since 2021, and it was scheduled for release a while back now....
It's crazy to think that the old NW Masterpact range of ACBs from Schneider had this functionality available for REF scheme, yet in the year 2025 (almost 2026), you removed one of the most useful features of the ACBs in favour of some far less helpful "digital upgrades"....
Kind regards, Ian Johnson (AWS)
