MTZ IEC61850 setting
  • Power Distribution IEC
  • MTZ IEC61850 setting
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Ray_Chang_EPEC
Lieutenant | EcoXpert Master Ray_Chang_EPEC Lieutenant | EcoXpert Master
Posted: ‎2022-11-04 12:43 AM
4
2228
Hi:
I'm triyng to use IEC61850 on a MTZ.
But I couldn't find a way to put CID files into EIFE.
Is there any manaul or video that i can look for this process?
Many thanks
  • Connectivity
  • Energy management
Ludovic_Soudril
Lieutenant JG Ludovic_Soudril Lieutenant JG
Lieutenant JG
Posted: ‎2022-11-04 01:09 AM
3
2221
Dear YinTse Chang,
You should find under the following linked the information you need;
MasterPact MTZ IED Configuration - MasterPact MTZ IEC 61850 Communication Guide (schneider-electric....
Please, note that the procedure to download the CID file is different for eIFE FW version up to V004.005.000 and for eIFE fw version V004.006.000 and Later.
Best regards
Ludovic
Replies 4
Ludovic_Soudril
Lieutenant JG
3
2222
Dear YinTse Chang,
Best regards
Ludovic
Ray_Chang_EPEC
Posted: ‎2022-11-04 01:22 AM
In response to Ludovic_Soudril
Thanks for reply @Ludovic_Soudril
I'll follow the guide and try it.
sesa232305
sesa232305 Cadet
Cadet
Posted: ‎2023-11-06 05:49 PM
1528
Dear Ludovic,
what's software you using for testing IFE (firmware V4.11) + MTZ (IEC61850)?
I already insert file cid.exi to IFE via filezilla software, but when I test using "IEC61850 simple tester" software is failed. I can ping IFE and already disable my firewall.
I test PM8240 using "IEC61850 simple tester" is work well.
Now, i'm very confuse How to test MTZ with IEC61850.
YonKhoerul
Ensign YonKhoerul Ensign
Ensign
Posted: ‎2025-04-06 07:29 PM
In response to sesa232305
Dear @sesa232305 you can use SCL Viewer.
