Posted: 2023-01-16 12:27 AM
The journey continues…
Since 2021, Schneider Electric, the leader in the digital transformation of energy management and automation, has announced a new generation of it’s respected ComPacT molded-case circuit breakers.
Starting 2023, ComPacT new generation will be extending to NS range, for high rating MCCBs and switch disconnectors up to 3200A.
A major design improvement is the introduction of a semi-transparent front faceplate. This innovation makes it easy to see at a glance which auxiliaries at work in the breaker, and that they are correctly positioned.
Thanks to the new commercial references, there is seamless offer selection and an easiest access to the circuit breaker configuration.
Schneider-Electric, declare that the New ComPacT NS range has identical platform as current Compact NS range. The new ComPacT NS ranges is built on the same technical and dimensional architecture. The electrical and mechanical performances remain identical.
Please refer to “ComPact NS Substitution and Technical Guide” (Document code: LVPED221007EN) for details :
Adrien Coulet
Global MCCB Offer Manager (support)
Power Products Division
Posted: 2023-01-17 05:42 AM
Hi
Take opportunities to read all new installation guide we redesign with this new offer,
I hope it will Help you to understand better the product and the installation constraint. You can download them on the web site or scan QR code on the document inside the box.
Posted: 2023-01-16 04:40 PM
Great L&F matching with rest of the line.
Hi
