KS Diversity Factor is not considered in sizing cables/breaker/transformer
Power Distribution and Digital Support
  • Power Distribution IEC
  • Power Distribution and Digital Support
  • KS Diversity Factor is not considered in sizing cables/breaker/transformer
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
Commander Gregoire_Brun Commander
71
J_Travostino
Sisko J_Travostino Sisko
70
S-W
Commander S-W Commander
67
Back to Power Distribution and Digital Support
EDBAS
Crewman EDBAS
Posted: ‎2024-06-04 12:56 AM . Last Modified: ‎2024-11-22 04:25 AM
656
The above topic has been marked as solved in a thread, However, in the latest version V2 released this May 2024. The above subject is still not resolved.
  • Power Distribution Software
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2024-07-18 01:22 AM
Hello EDBAS,
For answering your query,
Diversity factors are considered during modifying of Ks.
Transformer, Cables, Circuit breakers & upstream current (Ib) changing based on diversity factors on each level of busbars/Panels.
For that We have done analysis of 2 perspectives (Enabling operating modes for different diversity factors & Creating 2 projects in same range and different diversity factors).
Case 1: -
Diversity factors are considered during modifying of Ks, upstream current (Ib) changing based on diversity factors on each level of busbars/Panels.
For example, we have created trial projects with 3 operating conditions with
  1. Normal operating mode with full load i.e., Ks= 1.
  2. Working with 50% load i.e., Ks =0.5.
  3. Working with 70% load i.e., Ks =0.7.
We can see below for all the operating modes Transformer/Cable/Upstream circuit breaker are not same. Its changed with respect to given Diversity factor (Ks).
So, Diversity factors (Ks) are considered for adopting offer solution and range of Transformer/Cable/Upstream circuit breaker/Feeder circuit breakers.
Case 2: -
For this case we have cretaed 2 sysmetrical projects(All the connected loads are same range) but we have changed the Diversity factor Ks as 0.5 for second project.
Network 1 with Diversity factor Ks = 1.
Network 2 with Diversity factor Ks = 0.5.
We can see the below screenshots both projects Transformer/Cables/Upstream circuit breaker are not same. Its changed with respect to given Diversity factor (Ks).
Network 1
Network 2
Transformer/Circuit breaker/Cables details
Project 2 with 100% loading Ks = 1
Project 1 with 50% loading Ks = 0.5
MV/LV Transformer
TA0
3150 kVA
750 kVA
Circuit breaker
QA 0
MasterPact MTZ3 MicroLogic X - MTZ3 50H1
MasterPact MTZ1 MicroLogic X - MTZ1 12H1
QA 3
MasterPact MTZ2 MicroLogic X - MTZ2 32H2V
MasterPact MTZ1 MicroLogic X - MTZ1 10H1
QA 3bis
QA 6
MasterPact MTZ1 MicroLogic X - MTZ1 10L1
QA 7
MasterPact MTZ2 MicroLogic X - MTZ2 20H2V
QA 7bis
MasterPact MTZ2 MicroLogic X - MTZ2 20H1
QA 10
MasterPact MTZ1 MicroLogic X - MTZ1 10H3
QA 11
QA 12
Cables
WD 12
2x300 Sqmm
2x300 Sqmm
WD 11
2x300 Sqmm
2x300 Sqmm
WD 10
2x300 Sqmm
2x300 Sqmm
WD 7
5x240 Sqmm
2x300 Sqmm
WD 6
2x300 Sqmm
2x300 Sqmm
WD 3
7x300 Sqmm
2x300 Sqmm
WD 0
11x300 Sqmm
3x185 Sqmm
Conclusion: -
From the above analysis we came to know that diversity factors are considered during modifying of Ks.
Case 2 Ks factor with 2 Networks.eac
Case 1 Ks factor with operating modes.eac
Replies 3
Genghiz
Captain
Posted: ‎2024-07-03 05:43 AM
There was an issue in managing the given values (while opening the project file) and this has been fixed during the last release.
Can you please provide some additional information.
Team - Ecodial Expert Support.
Saravanakumar.L
Lieutenant
Posted: ‎2024-07-14 11:06 PM
Hello EDBAS,
Can you please provide some additional information (Screenshots, .eac files & Documents).
Saravanakumar.L
Lieutenant
Hello EDBAS,
Case 1: -
Case 2: -
Network 1
Network 2
MV/LV Transformer
TA0
3150 kVA
750 kVA
Circuit breaker
QA 0
QA 3
QA 3bis
QA 6
QA 7
QA 7bis
QA 10
QA 11
QA 12
Cables
WD 12
2x300 Sqmm
2x300 Sqmm
WD 11
2x300 Sqmm
2x300 Sqmm
WD 10
2x300 Sqmm
2x300 Sqmm
WD 7
5x240 Sqmm
2x300 Sqmm
WD 6
2x300 Sqmm
2x300 Sqmm
WD 3
7x300 Sqmm
2x300 Sqmm
WD 0
11x300 Sqmm
3x185 Sqmm
Conclusion: -
This is a heading
