GS2F3 ISOLATOR HANDLE
  • Power Distribution IEC
  • GS2F3 ISOLATOR HANDLE
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-10-03 03:07 AM
1
1481
I am looking to use a GS2F3 (switch disconnector) with front mounted handle (GS2AH520 or GS2AH540) but I need confirmation on the maximum distance the shaft can be for front mounted installation.
Enclosure I am using is 300mm deep.
https://download.schneider-electric.com/files?p_enDocType=Instruction+sheet&p_File_Name=534011F.pdf&...
The above document is what I am confused with as on page 3 it says 145mm maximum but you can buy 400mm shaft. I just wanted confirmation what I can use for front installation and if it's even possible.
Any feedback would be greatly appreciated.
Mike
Gregoire_Brun
Commander
Posted: ‎2022-10-04 07:12 AM
Hello @Anonymous user
As I understand x dimention is calculeded for a 200mm axle
But any reason to forbiden other axles
For 400 mm axle X becaumes max 345 mm, any techical risk
Hope it answer to your request
best regards
Gregoire Brun
Breaker Product Expert
Gregoire_Brun
Commander
best regards
Gregoire Brun
