Erreur fatal Ecodial 4.9.8 FR
  • Power Distribution IEC
  • Erreur fatal Ecodial 4.9.8 FR
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
jbprojelec
Crewman jbprojelec
Crewman
Posted: ‎2024-10-26 09:28 AM . Last Modified: ‎2024-11-22 04:25 AM
2108
Bonjour,
J'ai installé Ecodial 4.9.8, mais après l'installation quant je le démarre il affiche un message d'erreur et il ce renvoie tout seul.
J'ai installé .net Framework 3.5 qui est activé mais rien à faire Ecodial ne marche toujours pas.
Par contre la version Ecodial INT 5.2.0 normalement ainsi que la version Ecodial FR 4.9.6.
Merci de votre aide.
  • Power Distribution Software
  • france
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2024-11-12 06:56 PM . Last Modified: ‎2024-11-12 09:11 PM
Hello jbprojelec
As we have validated the log files and discussed with "Product Development Team."
The situation may be due to the PRM login.
As you have both the versions (France & INT) installed in same system, there might be the issue with the login registry.
So, we are suggesting the following workaround.
Step 1:  Please follow the below mentioned path and delete the XML file from V4.9.8.
Step 2: Re-launch the application.
It may rectify the issue. If it not resolved, we would have meeting to analyze deeply with all the aspects.
Thanks & Regards,
Team- Ecodial Expert support
Replies 4
Saravanakumar.L
Lieutenant
Posted: ‎2024-10-29 03:08 AM
1
2086
Hello Jbprojelec,
Thank you for reaching out to us.
By attaching your screenshot, it seems to be related to a .NET activation issue.
Please follow the procedure below to rectify:
.NET framework activation:
Step 1: go to windows> control panel>get programs> turn windows feature ON or OFF
Step2: make sure that the box against the .NET 3,5 is checked as below
Step 3: restart the system and reinstall EPD Ecodial
This should resolve the issue.
If the issue persists after the above actions, please share the log files with us for further analysis.
You can find the log files at the following path
Thank you for your cooperation.
Thanks & Regards,
Ecodial Expert support team.
  • Bonjour Monsieur
  • ici le fichier Logs
jbprojelec
Crewman jbprojelec
Crewman
Posted: ‎2024-11-09 04:42 AM . Last Modified: ‎2024-11-11 09:49 PM
In response to Saravanakumar.L
Bonjour Lieutenant,
Voici le fichier Logs (journal)
A bientôt de vos nouvelles
Merci pour votre aide
Saravanakumar.L
Lieutenant
Hello jbprojelec
Thanks & Regards,
jbprojelec
Crewman jbprojelec
Crewman
Posted: ‎2024-11-15 01:21 PM
Bonjour et merci,
Je viens de faire ce que vous m'avez indiquez et cela fonctionne maintenant.
Un grand merci
