Posted: 2024-04-08 08:17 PM . Last Modified: 2024-11-22 04:25 AM
Hello, I got a problem about cable constraint. I tried modified circuit breaker, increase cable size but no luck.
Do you guy have a solution to solve this warning?
Posted: 2024-07-03 06:04 AM
This would be a specific network scenario with a small load & less fault currents.
That you will not get a product to sense and protect it from.
If there is no solution of a product is found by the application, this should not stop by throwing an error.
Suitable improvement request will be communicated to the product management.
Team - Ecodial Expert Support.
Posted: 2024-04-15 10:12 PM
Hello
Thanks for reaching the EcoStruxure Power Design Forum.
Can you please kindly enclose the project file, for the further analysis by the expert team.
What is version of application used for the project file creation.
Team – Ecodial Expert Support.
Posted: 2024-08-30 07:20 AM . Last Modified: 2024-08-30 07:35 AM
I'm having a similiar issue with thermal constraints. @Genghiz Can you please see the ecodial file attached? Please advise solution to clear the problem with thermal constraint. Thank you.
Best regards
Posted: 2024-08-30 09:39 AM
The next higher size than the locked one (ie from 16 to 25 mm2 of the cross-sectional area) has avoided this warning.
Team
Expert Support
