Ecostruxure Power Design 5.3.1 INT - grouping factor
  • Power Distribution IEC
  • Ecostruxure Power Design 5.3.1 INT - grouping factor
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
AndrejsRo
Crewman AndrejsRo Crewman
Crewman
Posted: ‎2025-02-25 01:50 AM
969
I received a question from a customer who is using Ecostruxure Power Design 5.3.1 INT:
Any comments? File is attached.
"Hello, why does changing the Number of trays and Touching circuits not change the cable calculation results?
Shouldn't it take into account the coefficients from table B 52-21?"
grouping factor question.eac
  • India Power Distribution & Digital
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2025-03-24 03:39 AM
Hello AnrejsRo,
We have validated the query and confirmed that the cable installation method of 32 F and the IEC standard IEC 60364-5-52 respective table indicate the following:
If we have a maximum of 9 cables, including the touching circuits, the correction factor is 0.78. This correction factor remains the same for up to 20 touching circuits, including the respective cables.
Therefore, the cable calculation maintains the same 0.78 correction factor as per the standard.
Hence, Ecodial is working as expected.
Thanks & Regards,
Team- Ecodial Expert support.
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-02-27 12:36 AM
Hello @AndrejsRo, thank you for your post!
@Genghiz can you advise @AndrejsRo please?
Thank you in advance!
Saravanakumar.L
Lieutenant
Posted: ‎2025-03-12 08:09 PM
Hello AndrejsRo,
Thanks for reaching us!
We are working on your query.
Thanks & Regards,
Team- Ecodial expert support.
Saravanakumar.L
Lieutenant
Hello AnrejsRo,
Thanks & Regards,
