Posted: 2021-10-20 02:44 AM . Last Modified: 2022-11-30 05:44 AM
Dear Community,
I have an issue with Ecostruxure Power Commission. I'm unable to add a building or a switchboard in the switchboard view. When I click the "Add" then "Building" buttons nothing happens.
I tried different release of EPC and always have the same issue.
I'm also unable to add discovered devices to a project (it's probably the same issue).
Is there a way to diagnose this issue (logs,...)?
Best regards,
Ludovic
Posted: 2021-10-20 04:48 AM
Hello @l_lebacque_neu-
For all technical issues regarding EcoStruxure Power commission, you could contact your local support.
Please find the adapted contact in order to your own country on the following webpage :
https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
Best regards
Posted: 2021-10-20 09:30 AM
Hello @EPC_Leader ,
I reached local support and the issue is now solved.
There were an issue with SQL.
Thanks for your help.
Best regards
Hello @EPC_Leader ,
Posted: 2021-10-25 02:13 AM
Hello @l_lebacque_neu- ,
How did you solve this SQL issue?
Was it complicated and quick solving it?
Thanks for sharing your experience..
