Ecostruxure Power Commission Automatic Trip Report Serial Number issue
  • Power Distribution IEC
  • Ecostruxure Power Commission Automatic Trip Report Serial Number issue
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
BrianW
Lieutenant | EcoXpert Master BrianW Lieutenant | EcoXpert Master
Posted: ‎2023-02-22 07:01 AM
1832
Hi all,
I have just noticed that after generating Automatic Trip Reports from MTZ units that the Serial Number shown in the Trip Unit Details section is copied into the Breaker Details Serial Number.
The Trip Unit Detail Serial Number is correct, but the Breaker Detail Serial Number is therefore incorrect. Is there any way to "force" the software to pick up the Breaker Serial number and display that number in the correct location on the reports?
Brian
  • EcoStruxure Power Commission (EPC)
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2023-02-23 05:19 AM
In response to BrianW
1802
Hello
In fact, EPC get the serial number of the Micrologic by communication way, the software can't collect other part number in that mode.
Hoping clarify the request
Regards
Replies 4
EPC_Leader
Lt. Commander
Posted: ‎2023-02-22 07:36 AM
1826
Hello
in EPC, the software get only the serial number of the micrologic ( trip unit )
it is display inside the project :
it is display inside all reports :
Could clarify what you mean by "the Breaker Detail Serial Number" ?
BrianW
Posted: ‎2023-02-22 07:58 AM
In response to EPC_Leader
1824
In the PDF generated report, the Trip Unit serial number is copied into the Breaker Details serial number, rather than the actual PP serial number of the MTZ as per the attached image. Perhaps the MTZ Breaker serial number cannot be populated into the report?
Thank you for responding so quickly,
Brian
EPC_Leader
Lt. Commander
1803
Hello
Regards
BrianW
Posted: ‎2023-02-23 07:17 AM
Thank you Fabrice!!
