Ecodial calculation
  • Power Distribution IEC
  • Ecodial calculation
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
sesa21615_bridg
Crewman sesa21615_bridg Crewman
Crewman
Posted: ‎2025-03-11 01:50 AM
1006
Ecodial calculation
Hello, I am working on a simple project with a transformer of 2000kVA and 40m cable in the ground. It does not calculate the cables.
Do you have any idea why? Normally it should work. It is not something specially.
Regards and thanks for a quick answer.
Mihaela
TEG SE-Tibi.eac
  • Software
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2025-03-12 02:02 AM . Last Modified: ‎2025-03-12 02:02 AM
1
963
Hello sesa21615_bridg,
Thank you for reaching out to us!
We have reviewed your query and found that you have set the maximum permissible CSA to 240 sqmm for your project.
However, given your project’s cumulative load current and installation method, it exceeds 20 cables/touching circuits, which is not feasible.
In Ecodial, only 20 cables/20 touching circuits including its own cable are allowed for one circuit, so we recommend upgrading the maximum permissible CSA to 300 sqmm.
This adjustment will ensure that Ecodial operates as expected.
I hope this clarifies your query. If you have any further questions, please feel free to ask!
Thanks & Regards,
Team- Ecodial expert support.
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-03-11 06:52 AM
Hello @sesa21615_bridg, thank you for your post, we'll come back to you!
Saravanakumar.L
Lieutenant
1
964
Thanks & Regards,
sesa21615_bridg
Crewman
Posted: ‎2025-03-13 01:02 AM
In response to Saravanakumar.L
Hello, Thank you! You are right!
