Posted: 2025-09-27 05:56 AM
I have an EVlink pro ac charger that i want to integrate with a mid certified mete.
The charger in its datasheet says it supports modbus tcp and the meter supports modbus rtu, the instruction sheet for the charger shows a specific terminal block I for external MID meters that is not soldered on the actual charger.
part numbers
EVlink: EVB3S22N4FB
Meter: A9MEM3155
should i get a modbus rtu-tcp gateway or is there another way?
Posted: 2025-09-29 12:06 AM
Hello
Yes you can add one external MID. Either via ModBus TCP (and so a gateway) or directly in ModBus RTU.
Please have a look to the instruction sheet :
https://download.schneider-electric.com/files?p_enDocType=Instruction%20sheet&p_File_Name=EVlink_Pro...
Hello
