EPC issue when programming MTZ2
  • Power Distribution IEC
  • EPC issue when programming MTZ2
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
BrianW
Lieutenant | EcoXpert Master BrianW Lieutenant | EcoXpert Master
Posted: ‎2024-02-01 02:32 AM
944
Hi all,
I am in the process of secondary injection for a large number of MTZ2 breakers on a switchgear panel and have hit an issue that I have not seen before with the EPC.
I can communicate to an MTz2 no problem, I can rename the breaker which updates fine, but when I try to enter the Commissioning Date, entering the password, the EPC reports back that it is "Unable to write to the device". I repeatedly tried this, re-read the breaker, skipped over this Commissioning Date and the breaker goes on to be able to successfully pass the secondary injection perfectly.
But I do need to set the Commissioning Date (for alarms, etc.) I am using the latest version of EPC v2.30.0, but this is the first time I have used this version for secondary injection, perhaps there may be a bug in this version?
I'd appreciate any help as this is now preventing my progress...
Thanks in advance,
Brian
  • EcoStruxure Power Commission (EPC)
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2024-02-06 12:10 AM
Hello
That issue is not known with the V2.30
I advice you to contact your local Customer care center to share the issue and open a case to raise it to our technical team
Thanks for your understanding
EPC_Leader
Lt. Commander
Hello
