Do we need to reset the circuit breakers after a power outage?
  • Power Distribution IEC
  • Do we need to reset the circuit breakers after a power outage?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
  • Comunidade de Soluções ElĂ©tricas
Posted: ‎2021-07-05 04:01 AM
2309
Hello all,
After a power outage (either at the factory level or at the panelboard level), do we have to reset the circuit breakers?
I mean: the settings, the pairing (if some wireless connection to a gateway), ….
  • Operations & Services
  • Power Availability
  • Products
RHH
Commander | EcoXpert Master RHH Commander | EcoXpert Master
Posted: ‎2021-07-05 04:39 AM . Last Modified: ‎2021-07-05 05:08 AM
1
2305
Hi @Anonymous user,
NSX's settings remain as they are as most of the functions of the NSX are physically programmable on the circuit breaker itself (rotational sliders) The communication to the outside are probably indicator signals?
Whether the circuitbreaker is ON/OFF with an power outage its obviously signaling its off, or displaying an malfunctioning current (no current) so it wouldnt be any issue? Same signaling with any other software related connection.
I think best thing to do is switch every circuitbreaker off first, then turn back on head switch and 1 by 1 re-switch every circuit breaker on and see if the communication and everything turns back to normal (in monitoring tool as well).
EDIT:
If there are components with communication over MODBUS/Ethernet it should stay the same as well.
Everything should have a static IP address and when they are back online the monitoring tool should be able to see them again.
Depending on the component; Most components have a small battery that hold on to the internal settings of that component/communication.
Kind regards,
Rick
RHH
1
2306
Hi @Anonymous user,
EDIT:
Kind regards,
Rick
Posted: ‎2021-07-05 05:58 AM
In response to RHH
Thanks for answering @RHH. đź‘Ť
