ComPacT NSX Maintenance recomandation
  • Power Distribution IEC
  • ComPacT NSX Maintenance recomandation
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
ComPact NSX
ComPacT NSX, new generation
ComPacT NSXm, new generation
field url
ComPacT for DC networks, new generation
Load more
Gregoire_Brun
Commander
Posted: ‎2022-04-04 08:31 AM . Last Modified: ‎2022-04-05 12:52 AM
5
4378
Hello All
From your knowledge and experience, what are the maintenance recommandation you give to your customers about MCCB's when you design an equipment?
Your feedback is very important and helpful for us.
Thanks a lot.
Gregoire Brun
Breaker Product Expert
  • Operations & Services
  • Products
  • Safety - People Safety
  • Schneider Partner Programs
HelvinHermanT
Admiral HelvinHermanT Admiral
Admiral
Posted: ‎2022-04-19 12:53 AM . Last Modified: ‎2022-04-21 09:13 PM
2
4182
Hi Gregoire,
According to my experiences, there are some maintenance that can be propose to users :
A. For high current Circuit Breakers (LV / MV) :
  1. Preventive maintenance such as :
    1. Visual check (Contact wear, sign of Burned, leak, water, etc)
    2. Cleaning & re-greasing on the operating mechanism (moving parts)
    3. Some parts may need Electrical Grease (Finger Contact)
    4. Torqing on the bolt & nuts to avoid loosen connections that create heat. Consult manufacurer for torq value.
  2. Predictive Maintenance using Diagnostic tools
    1. Circuit breaker diagnostic tools to check any deteriorating performance parts (Opening & closing speed, over travel, maoin contact wear, etc)
    2. Check on the contact resistance
    3. Check on the tripping curve of the Tripping Unit.
B. For low current circuit breakers such as MCCB
    1. Visual check (sign of Burned, leak, water, etc)
    3. Torqing on the bolt & nuts to avoid loosen connections that create heat. Consult manufacurer for torq value.
  2. Predictive maintenance
    1. Using Thermography. With the thermal imaging camera or just spot measurement you can detect any potential problem such as loosen contact (higher heat on connections) or overload (heat on the MCCB).
    2. Some MCCB have internal embeded facility to check for the internal contact wear (Self diagnostic)
    3. Check on the tripping curve using Micrologic testing tools
The are many level of maintenance that can be done by user, trained engineer or by Manufacturer.
The Periodic maintenance Schedule is also can be defined based on criticality of the load.
Hope help.
Peter_Hall
Lt. Commander | EcoXpert Master Peter_Hall Lt. Commander | EcoXpert Master
Posted: ‎2022-04-19 01:06 AM
In response to HelvinHermanT
1
4178
Some interesting thoughts on this topic.
I never cease to be amazed that a customer buys a brand new LV switchboard and then hands over the maintenance to a contractor who cannot provide any evidence of manufacturers training or authorisation. When the works are completed the customer is left with very little or no evidence that the work has been carried out. Who would buy a brand new BMW and hand it over to a friend who is 'good' with cars to look after and expect BMW to pick up any warranty claims found by this 'friend'?
With the advent of the new range of communicating devices servicing of devices and service history should be much easier. Servicing could be monitored via the adoption of 'Service Centre' badges. EPC could be adapted to run a servicing regime on devices. This would leave a service history stamp on the device and upload service information to FE Logbook for the customer to access. All service steps could be incorporated into EPC., This would ensure a level is maintained and cannot be open to interpretation or confusion as to just what is required on a certain device.
Gregoire_Brun
Commander
Posted: ‎2022-05-13 06:17 AM . Last Modified: ‎2022-05-13 08:42 AM
In response to Anonymous user
We do like explain by @HelvinHermanT
And it's specified in all user guide we edit for all products.
Document can be find in our website ( tell me if you need one in particular)
Gregoire Brun
Gregoire_Brun
Commander
Posted: ‎2022-05-13 06:20 AM . Last Modified: ‎2022-05-13 08:44 AM
In response to Peter_Hall
Hi Peter
Your example of the car is good because even if you buy a Dacia or a Porsche, every year you go to the garage to change oils and make some maintenance checks. That's what we fiel for electrical device as something needed...
Gregoire Brun
Replies 5
Posted: ‎2022-04-10 10:58 PM
1
4285
Hello @Gregoire_Brun ,
Aren't there any recommendations made by manufacturers as Schneider Electric or others?
What about the warranty if customers don't follow them?
HelvinHermanT
Admiral
2
4183
Hi Gregoire,
Hope help.
Peter_Hall
1
4179
Gregoire_Brun
Commander
Gregoire Brun
Gregoire_Brun
Commander
Hi Peter
Gregoire Brun
